Whatever your decision if you go log make sure your builders know their stuff and ask for references at least 2 years old. Improperly done log homes settle a lot in the first couple years and next thing you know window and doors bind and don't open for chit. I have a friend that got burned on a $300K build (just the matl and labor for the build) because of improper planning for the settling.
As a builder that does both, if I was to build a cabin, it would be of logs. However, I would be torn on what style of logs to do it with. If you like the milled log look with a Swedish cope, you will have very little settling, and therefore be able to make a fairly tight cabin. If you prefer the look of a hand scraped log, you will have to deal with settling, gaps, and adjustments.
What's your guy's opinion on those log cabin kits? My friend and I are looking at some property in the Fairfield (Idaho) area and we were planning on getting a kit to put on it. Any experience/suggestions?
Thanks for all the idea's and info.
One other question about water, to have a well drilled where I am is about 23,000 dollars. What do you guys do that don't have wells? I am thinking about putting a 800 gallon fresh water tank in the ground and fill it before the snow flies, anyone tried this? I figure that's 5 or 6 trips in the winter.
Ask around and see if anyone around you is building ~the same time. Group your well/septic work together and go for bids. 2 or 3 of you drilling wells at the same time might be able to negotiate that down quite a bit.
