Broken bolt help
There are a few ways. Cleanest is to drill and use an easy out, or you could weld a bolt to it and back out the bolt with a wrench, could try to grab it with a vice grips(if there is anything to grab onto), and if all else fails start drilling The center of it and hope it let's loose before you have to drill the whole bolt out and re-tap the threads. (I have gotten lucky a few times starting with a small bit and working up, it seems sometime taking the center out of the bolt it looses it's hold on the threads and will start to spin with the drill bit.) Good luck!
heat is your friend in this situation, make sure you heat it up good because of the loctite. you maybeable to spin it out but probably will need either one of the options stated above
Drill a small pilot hole in the center, rmk boxer is right heat is good, get yourself a left handed drillbit and hopefully it grab hard enough to back the bolt out.
Yes, it's a pretty tedious job getting the step out without bending everything up. I did the same thing on an old mid 80s chassis 10 years ago and couldn't find the correct part(step) so I had a machine shop remove the broken extractor and bolt. They used a torch and then retapped the hole.
snaped off
take a 7/16" nut put over the broken bolt weld them through the center with a mig welder the heat will help the locktite let go should back rite out , somtimes it takes a couple times / good luck
This was a poor setup by Polaris in the first place. This is why You see Bolts all the way through on the PRO X chassis.
