J
jim
Picked up a Highmark Shift (600cc) turbo last week and broke her in this weekend. Rode in McCall...good crust up there but good coverage and very rideable. I took about an hour to tune it in as I was being very conservativea nd wanted to make sure I knew where rich was....left it pretty rich when transitioning into boost just to be safe. Running 10 PSI with AV gas (which works very well despite the rumors against it).
This sled is unreal...you really don't need much more than 1/2 to 3/4 throttle, plus I'm trying to take it easy on the new motor. My max track speed was 66...and that was not from the trail and I was not pushing it hard. Good traction also...I expect it will run around 75 MPH track speed in lighter snow and on full throttle. Never exceeded 8100 rpms. Super light and flickable...should be in the 470 pound range. You can pick the skis up at will and it does not wobble...very true and predictable climber. Turbo is super responsive also...you could get on and off at will when climbing and it responded. And this motor sounds pizzed off! Great sound...sounds like it has a can as you are tooling around and once the turbo spools up all hell breaks loose. Lag...yeah, all turbos have it, but it is very minimal. I'm also rich in the transition, so it'll pick up as I lean it down in the near future. All in all I'm very happy with this sled...will put more miles on it soon...can't wait to get it wide open for a long section...I'm sure it'll be crazy.
