P
paulharris
well, for those thinking of putting a 2011-2012 shaft in their 2013 with belt drive you might want to check your shaft for runout. I just recieved a brand spanking new 2012 shaft, took it out of the box, put it on a jig that i made to spin it and make sure it was true.....i was shocked at what i saw. the splined end that the belt drive sprocket goes on is way out of true. this is a brand new shaft. i estimate it at least .015" out of true. it is clearly visible with your eye. it is a wobble at the end and you can see it all the way up to where its welded on the shaft. it is un-usable in the 2013 because that runout will magnify itself on the belt drive pulley creating a "loose-tight" wobble and thus eat up the belt.
so clearly the tolerances on these welded shafts are not very tight. this really makes me mad that the quality control is this sloppy. perhaps some are ok, but even the smallest amount of runout will surely make big problems for the belt drive.
See pics attached. you can see where they cylindrical grind the splined end and the parts where the grinding wheel never touched because of the wobble. clearly their jigs are not accurate enough to produce a precision part.
This really makes me think that the best solution may be a standard hex shaft machined out for this sled.....there will be NO RUNOUT because there is no welding, no gluing, no 3 piece assembly. it would be a perfectly straight shaft.
Is polaris building tractor parts here? now i have 2 POS driveshafts. disgust
