Brand New 2013 Pro 800 Engine
Devilmanak
Brand new takeout engine. No miles. This will bolt into a 2011-2012 Pro if you use 2012 injectors, and according to Carl's you will need a $75 ECU reflash. (At least on the 2011, not sure on the 2012 if a reflash is needed.)
EVERYTHING else bolts right on! $3300 shipped US as pictured. $3425 shipped Canada.
Knock $50 off for local pickup in Donnelly, ID.
Knock $75 off if you don't want the oil pump.
Knock $75 off if you don't want the exhaust valve tops. (You DO need the valve blades themselves, they are included either way.)
Chris
