Brake indicator light stuck on
E
Err
The brake light indicator on the dash display is stuck glowing on my pro. The brake light its self is behaving normally. The brake is not actually stuck on and the track spins freely by hand. All was fine during my first ride, 25 miles, but the light was on when I unloaded from my truck at home. Brought it in the garage and dried it off, even tried blowing out the area around the lever with compressed air. No luck.
Anyone else seen this?
Mine did the same thing this week, I keep monkeying with the lever and it started working after a while. I was thinking that might have had some ice in rubber boot on switch but if still does it after garage duty can not be that.
My 09 Dragon had this issue. The light was always on, if lever was depressed just a little it would go off, then come back on with more pressure. Never did figure it out!
Hmm, sounds like something is slightly out of spec and maybe exacerbated by a little moisture. Might try again to dry it out with a little warm air. Prob just ride it until it's convenient to drop it at the dealer for a fix.
Same for me, had the light on for a while. Thought was snow build up and eventually went away...
Really touchy switch!
mico switch...
Just ride it!
Went out and fired it up again, been in the heated garage over night, no more light. Prob was just a bit of water or ice trapped up in there.
