Bought an '02 with a custom tunnel and it doesn't run the coolant lines to cool the brake caliper. What are the options out there to run a different set up? Thanks!
Not sure what you are asking. What kind of coolers does this chassis have? Tubes down the runnig boards? U cooler? XC style tunnel coolers? Does it have a front cross over? Rear cross over or are you asking if you have an option to add the cooler back to the brake?
The cooler now runs down the center of the tunnel and doesn't have coolant through the runningboard edges. I'd like to get rid of the factory caliper setup where the coolant lines hook-up as I wont be running the lines there again. I see that there is a wilwood caliper that would work. Thanks, again!
Just run it without the coolant lines hooked up. It won't hurt anything. Never really understood why Polaris ran hot water out of the motor into the break any way.
You can unbolt the coolant cover off the top of the caliper as well and get rid of that.
been awhile for brakes, but if i remember correctly the rotor from a (somebody help me out here) pol 440 race sled? or similar is factory drilled and slotted and cheaper than a stock replacment! seems like it was 20 bucks but like i said its been awhile and i hope im not passing bad info. but definetly worth looking into.
