Bottom end bog on 01 800 rotax engine
Summitstef
I finally took my sled out last night for a little rip. I have one little problem in the form of a small bottom end bog. When the sled is at a dead stop and I gun it, there is a small bog , and when I am rolling a bit and gun it, there is no bog at all. Now I'm assuming that this is a jetting issue but please correct me if I am wrong. I have installed the new Boysen cage rage reed system, and put a set of K&N podds with prefilters. Any suggestions would be appreciated! :confused:
Possible plugged pilot jet? Is it the first ride of the year? Seems like I have to clean mine every winter!
check your pilots. you might have to go up one size with the air box off. I have run pods on mine for ever. stops the flooding when you tip it over.
Had The Same Problem With Mine For The First Ride. Came Home And Went Right Through My Carbs. Put Them Back On And Has Never Ran Better. Get Rid Of The Pods Too. Tried Gutting The Airbox Too. They Dont Work. Stay With The Stock Air Box. They Made Them For A Reason. Not Like A P.o.s Polaris.
