seano700
Hi guy's
I went out for one last ride last week. Sled ran good but no matter what I did I could achieve 12lbs boost, (was running @ 10lbs). I opened my bleed valve (boost controller right up) and then shortened up the linkage to my wastgate. Still only 11lbs boost. Once I got home I found my idle air control line had popped off leaving a half inch hole in my intercooler. Problem solved. I was talking to a buddy about it afterwards and left the conversation with a few questions.
Lets say at 10psi boost an engine makes 10 hp (no boost leaks, everything is perfect). Now lets say the same engine is still making 10psi boost but has a boost leak (like I did) how much power does it make? According to my buddy it will make less power due to inefficiency of the turbo. To me boost is boost, but I am certainly no expert on the subject. Any insight you can provide would be appreciated. I would just like to wrap my head around the whole situation. Thanks Sean
