2013 Pro RMK Supplement
The 2013 Pro wiring harness is slightly different than the 11-12 Harness, so the wires for the Tmap interceptor must be extended in order for the Tmap sensor to reach the air box.
The solid white wire that is used for the tach signal is now in a larger 6 pin plug, but it is still a solid white wire.......
The only solid white wire that i found is going from the engine ecu to the mag side ignition
is this the wire?? cant find any "Larger 6 pin plug" thankful for help. send me a picture if i got wrong wire
