Boonedocker turbo oil
What oil is everyone running? Boondocker recomends either thier oil or a synthetic two stroke oil? Kinda seems wierd to run a two stroke oil in a turbo.
i just use my apv oil, changed it twice last season. about 800 miles each change.
was told just to change it once a season, and to check levels every ride...
thats what i did/do.
Same here. Told apv works well. Just refilled mine again with it. Breaks down a bit over time so check levels. But worked great so far!
Just use what ever 2 stroke oil that you are using. I used APV on my 09, and I am running Torco on my 11 no problems so far, change it 1 or 2 times per year and check your oil before you ride and all should be good. Enjoy the boost!
imgres
stop buy some time and we can walk outside and pull the drain plug on one of my vehicles with it idling and I'll give you $100 bucks if it seizes in 10min. I've even got a junker we can drain and run it down the road. Funny you call something junk when you don't have a clue. I've proven this stuff.
I think I'm gonna switch to running the Legend stuff in my turbo, same as in my sled .... I ran the Shell Rotella T6 all last season and my turbo compressor housing, charge tube and IC are totally gunked up right now to the point I am gonna have to find a parts washer to clean it all out. I'm hoping the 2T oil will be a little easier on the buildup.
I was running rotella for a long time in diesels and then started loosing oil and other weird stuff??? not sure what was going on but quit using it after my duramax blew up. Friends noticed same thing and switched also.
