T
theshadowrider
Help!
Okay so I am going to do a build thread of my install to show what it took to install. Until then I have a few questions. So far I have been impressed with the quality of bd.'s kit. I have run into a problem though. Trying to hook up the charge tube to the intercooler and it won't line up. I have a 2008 155 dragon and I guess on my sled it has the option of the extra heat exchanger. Boondockers told me that only a few 2008 dragon 155 have them. So, coming off the head there is a fitting in the way of the charge tube. This is the fitting that a line is hooked up to running to the heat exchanger on the front of the tunnel. From there it then runs to the over flow bottle. Boondockers told me that I need to bypass the cooler so the charge tube will work.
I think that some times people assume you know what they know. So, I found a thread from mountain horse talking about this. From what I can tell I will need to buy a new thermostat, head plug, and over flow. What I am thinking is I will put the plug in the head, and change the thermostat, and the overflow. Then I will just leave the cooler in and maybe next year when I change the track out I will remove the cooler? Do you think there will be any problems with this? I just don't want to remove everything that is needed to remove the heat exchanger, because it looks like I will have to have the track off to do so.
Is it nesscary to change the thermostat when getting rid of the heat exchanger? (I did notice there are two part numbers for two different thermostats, one with the exchanger and one without) Thanks for your help!
