boondockers T APEX
why does my 2007 boondockers turbo apex randomly shut off??????
Anything happen before it shuts off?
Backfire?
Loss of Power...Bog?
Whats your AFR's?
What elevation are you running?
What kind of Gas are you running?
Running a Boondocker Box or other fuel controller?
Any Codes showing on the Gauge?
Your gonna need to fill in the blank info cause there's allot of things that can make a sled shut off.
tpex
there is no bog but its only happened once........ im running 12 pounds of boost with 50/50 race gas and pump gas. there is no back fire. it is simply a clean shut off..... the only thing that comes to mind is that the previous own put renthal fat bars on it and never hooked up the hand warmers and when you bump the controls it will flash a check engine code. would that code make the engine go into a retard mode and shut down the engine????
what is the code,low oil pressure will shut your engine off,tors will retard the motor
