Boondocker???
I just bought a 05 king cat 900 it has a D and D pipe and it has a boondockr box i have nver beenaround this set up. the sled is set up for 10000ft and i live in iowa at see level will i need to shang the settings on the box for around here
for sure, you can find how the boonedocker works/ instructions on boonedockers website. You can also get a hold of D&D and they can give you starting numbers to run with.
damn does everyone from iowa spell like that?
back to the issue, if you dont want to mess with the box, unplug it, take off the pipe and run the stock pipe with the thing can.....stock AC pipes are good pipes for the motor...to be honest unless you are doing anything with the mill you're not really going to need to run an aftermarket pipe.
if you try and run that thing hard on rivers or ditch bangin on fun runs you're going to squeak it....they are mapped a bit different than the ZRs
