G
ghost rider
I took my boondocker pro out this weekend to test all my latest tweaks.
I've got it running pretty sweet. With the cold air intake and the third injector working and turning on at 5lbs i never saw my charge temps over 135 degrees. We were riding in 60 degree weather which is saying alot. I did chute pull after chute pull at 10lbs and it ran flawless on 50/50 Av/Premium.
Track speed in heavy slushy snow at the top of each pull was 62mph at 10.5lbs and at 9lbs it dropped of to about 52-55 mph. I didn't think there would b that type of difference but 1 pound of boost is alot. The bottom and top end run flawless and even better than our stock pro response wise. I did change my reeds before the ride and i did double stack the bottoms. I wanted to see how the third injector helps with cooling and lubrication for longer reed life.
So the interesting part was when i turned my third injector off and tried to run the same boost levels the HP went down quite a bit, the charge temps went from 135 to 186. By having my third injector on at 5lbs i thought my mileage would go down quite a bit but i rode 52 miles and still had a quarter tank. We were riding in 3ft deep wet snow all day so all in all the sled performed perfect at those levels. So in 30 degree outside temps or lower it should run even better.
http://youtu.be/4UdaDSH1MyE
http://youtu.be/pDMuhfY0h4g
A couple short videos of this weekend
