Boondocker turbo pipe
I was going to get the boondockers one but changed my mind. I guess it runs awesome on the top but bottom end isn't as good unless you wrap the pipe or put the 2010 heat shield on it. I have an 09 hcr so I assume my shield won't fit.They are trying to fix the problem as we speak. I will let them fix it and then buy one. I would rather have it stronger on the bottom
no bottom end power problems on mine. I'm on boost most of the time even while boondocking. once you tune your box proper for it, it rips. but you do need to wrap it and your rite the 09 shield doesn't fit.
They sure make for a nice install on a new application. Not having to cut and weld the stock pipe was great. Power band was great all the way through on the 2010 I have ridden (no pipe covering).
