Boondocker settings for cutler dragon 1000 motor
av8er
Ski-Doo Klim 509 BCA
hello , I ran my cutler dragon 1000 motor for the first time today at 6000 feet and 29-33 degrees out, and it had a bad bog at 1/2 to 3/4 throttle and would get worse at full throttle, I tried leaaaning out my boondocker box at 5000 and 6700 rpm by dropping the mid setting to 1, it ran better but put my sled's egts in the 1300-1380 range real fast , I was hoping u would share some settings with me, I greatly appreciate it. tHANK U
My speedwerx 800 I'm running 12-2-0-0 at 6700 so with a 1000 you should be at least in that area if not higher. You're probably experiencing a lean bog especially if your egts get that hot that quick. Even on my settings I can get close to 1200 over a mile or more at 6000rpm. Here are my #'s start with them and then you'll still probably have to add a bit of fuel being it's a 1000.
3000 0-0-0-0
5000 3-0-0-0
6700 12-2-0-0
7800 0-2-9-0
8100 0-2-9-0
Thats what I ran today and it still heats a bit around the 6000 mark on low throttle so I'm gonna up my 5000 probably to 4-2-0-0 and try that. Good luck and don't hit that 1300+ too many times or your new motor will have to be brand new again.
