Ok, so I fired up the sled today and tried to go through the initial EBC calibration like it says to do in the instructioms.
The fuel control box now reads zero on the boost at idle.
The EBC now for some reason only displayed the boost set point.
Shouldn't the EBC read zero at idle? It just displays "8.5" continually.
I also tried running the RPMs up a little on the track stand, it does not appear to be building any boost at all at 5,000 rpm (just off clutch engagement) ...
What RPM do these kits typically start building boost at?
Ok, another question ...
Lets say I DONT want the altitude compensation on to start with, I want to get used to manually setting boost, etc..
In the BD instructions, there are some lines regarding "SET BST" and "SET HP" ...
SET BST meaning what boost level you are targeting, set HP being the duty cycle of the wastegate ...
It says you have to add both ot get total boost? What does that mean and how does that work ....? Shouldn't the "SET HP" be a function of boost setpoint?
Is the SET HP only for using the push to pass buttin when you want to add boost manually?
I guess I don't understand why the push to pass even exists if it's setting duty cycle on the waste gate as opposed to adding 1/4 of a psi of boost or something ...
Here is a step by step through the NEW (2011) Boondocker EBC operation.
The first screen that comes up on your Boondocker EBC is “SET BST”(set boost). You can adjust this number to set maximum boost. As long as you remain on the set boost screen, the set boost setting will be displayed until you actually start to build boost.
The second screen you come to is “SET HP”, this is the amount of boost the EBC will add with the push to pass button. Again as long as you remain on this screen, the set value will be displayed until you actually start to build boost.
The third screen is “ALT” (altitude), this screen will display your approximate altitude. Again as long as you remain on this screen, this value will be displayed until you actually start to build boost.
The next screen is the “CFG PT CAL”. If this screen does not come up and you need to make a configuration adjustment, go to the “ALT” screen and hold the button down for five seconds. You only want to adjust this value if your EBC is connected to your Boondocker Control Box harness, and the control box is not using a separate pressure transducer. You have to adjust this with the sled idling and the Control Box on the “Stats-RUN” screen. You can adjust this value until the Control Box Reads 00.0 at idle, if the Control Box already reads 00.0, then on adjustment is needed.
The second screen in the configuration menu is the “ALT CMP” (altitude comp), you can set this to add or subtract one psi of boost for one psi of ambient air pressure change, or you can set this to “X2” to add or subtract two psi of boost for one psi of ambient air pressure change. You can also turn this feature off by selecting “NO”.
The third Screen in the configuration menu is, “BZZ” this can be used to test your boost solenoid.
The forth screen in the configuration menu is “BST U-M”, use this screen to select PSI or BAR for English or Metric units of measure for your boost reading.
The fifth screen in the configuration menu is “ALT U-M”, use this screen to select “KFT” (thousands of Feet) or “KM”( thousands of Meters) for your altitude reading.
The sixth screen in the configuration menu “REV”, displays the version number of the program that you EBC is programmed with.
The last screen in the configuration menu “XIT CFG” is the exit configuration screen. To exit configuration mode hold the button down on “YES” until “YES” flashes then hold the button again until “YES” is solid, then press the button to advance to the next screen. This will exit you from the configuration mode, and now your EBC will only cycle through the “SET
BST, SET HP, and the ALT” screens.
This should clear things up. Let me know if you have any other questions.
Thanks,
Junior
