H
Hangtime
New member
Just installed the auxliary injectors in a Boondocker pump gas unit. Installed the fuel pump booster , changed all fuel L & H settings and fuel RPM settings .. Duty cycle is still at 99% ... Temps are pretty normal on EGT 's. very sluggish out of bottom end .. Live in mn , main reason I did the extra injectors was because of my elevation and maxed out duty cycles at 7 pounds boost ..
Thanks for any help you can give ....
