boondocker controller ?
does anyone know the throttle positions on the 2014 controller? there are 6 positions and I can't figure out the throttle %
Posted from Snowestonline.com App for Android
are you talking your tps settings..??..
if so your controller shows the min and the max when running in the proper mode..subtract the min from the max then divide by 6 and then add that value to your min and repeat up to your six positions in the tps setting mode..
or you should have a duty cycle mode that can be used instead of tps settings and as well you can use fixed or percentage settings for adjusting fuel..i use percentage..
1-2 are low throttle 3-4 are mid 5-6 are high I have this box pm me if you have any questions
I'm trying to match up numbers from my powercommander. PCV has rpm and throttle position 10% , 20% , 50% etc . I want to know what throttle postions boondocker box runs.
The power commander has a lot more broad ranges to adjust fuel you will just need to compose it down and move it figure 1-2 being from 0 to 35 percent and 3-4 being 35-70 percent and 5-6 being 70-100 percent if you look at you should be able to get it pretty close
