Hardass Well-known member Lifetime Membership Jan 15, 2013 #1 Are boondocker boxes ac or dc? It gets power from the injector and is grounded to the chassis correct this is in a 09 m/1000 09s are ac but to everything? thanks
Wheel House Motorsports Well-known member Lifetime Membership Jan 15, 2013 #2 if they are powering up from the injector they are running on DC. all fuel injectors run 12v dc systems on sleds. looking for power for the boost it?
Hardass Well-known member Lifetime Membership Jan 15, 2013 #3 Yes i am and the afr? Will i need some sort of converter?
Wheel House Motorsports Well-known member Lifetime Membership Jan 15, 2013 #4 you can just get a small rectifier to switch some AC from the accsory circuit for it. i will dig you up a picture and explanation tonight
Hardass Well-known member Lifetime Membership Jan 15, 2013 #5 Thanks trying to see what the needs will be
Wheel House Motorsports Well-known member Lifetime Membership Jan 15, 2013 #6 ac/dc rectifier. you can get them at radio shack for like $5 "bridge rectifier" looks like this 2 terminals get the AC wires and then you have ground and +12V DC.
N never enough snow Active member Jan 15, 2013 #7 You can get the power for the air fuel gauge of the reverse beeper cct
Hardass Well-known member Lifetime Membership Jan 16, 2013 #8 Thank you NES Thats a big help NOW i need a total of 3 amp max for my controller any ideas?
N never enough snow Active member Jan 16, 2013 #9 beeper cct will take that draw i have a pro logger and egts on my sled off beeper cct note only 12v dc at beeper no grd
K kcdavidak Well-known member Jan 16, 2013 #10 just curious what part of the stator does beeper get it's power.trying to balance power usage.
