Bolt stuck now what
cubby
I'm in the process of changing tracks on my 05 800 and one of the rear suspension bolts that hold it the rear of the suspension is stuck, it just sits there and turns. I tried putting the other side back in but it just loosens up when I try the other side. Any ideas on how to get the bolt out or do I just need to cut it off? TIA
get a longer bolt with a nut and thread into the side that comes out, thread the bolt in a ways, then tighten the nut tight, now hold the nut with a wrench and loosen the other side, once its loose put a wrench on the nut and bolt and loosen the nut...should work for you...
