I was wondering if any body has had problems with their spark plug boots? I went out this weekend. I got about 2 km down the trail and it was bogging with no power and would not clear itself. It was like I had a fouled plug. I changed the plugs and no improvement. The week before I replaced a blown throttle body boot and reeds. So when this happened I was sure I leaned it out and cooked the pistons. I got home. Did a compression test with w.o.t. with the starter I had 115 to 120 psi compression. I was expecting higher, maybe around 150 psi. So I disassembled the top end. Expecting to have to have a problem. The dealer said the compression I had is normal. It all looked good. A few minor scuffs on the piston but other then that it looked good. I honed the cylinders, installed new pistons while I was there and put all back together. As a last effort I replace the spark plug boots and ends with ones from SLP. The dealer said they have some problems in the past with them. After I got it all back together and was warming it up I lowered the 3000 rpm low setting on the BD box to -3. The idle soothed out and it seems to be running good. Still have to take it out now to break it in and test it. If it wasn't the spark plug boots I don't know what else it could of been. Or has anybody have had problems with the BD pg turbo kit box acting up when it is really warm out? Just looking for some answers. Thanks.
