E
extremsledder
New member
So I have an idea that came to my mind and I was wondering your guy’s opinions. so my thought is I have a set of 900 cylinders that need to be renicked and my thought was can I take and boar these cylinders out to fit m1000 pistons in them and I have found out that they use the same top bearing, and buy looking on line at where the ring split is it looks close. so my question is has anybody done this or had the 2 pistons side by side and seen if there is a huge difference it height from the pin to the top of the piston and if the ring split will work with the port lay out in the 900, also is there room to boar the 900 cylinders 5.3mm's over without having to sleeve them? or if i was to sleeve them is there room in the sleeves to go that big? because if I was to use these they would have to be nicked anyways just a thought what do you think also the stroke on the 900 is 2mm shorter than the 1000 and is the pistons from the 1000 can be used it works out to being a 974 and that would be cool considering it would be using a stock piston that’s easy to get
