To the OP,
I am biased, but for the the M's my EZ Boards cannot be beat.
They fit to the boards like a stock part. They run from side to side and end to end. All the other alternatives do not. Not even close.
They are thin enough that the board edge grip is not diminished like the others. NO need to add more plastic on your edges.
Plus, the EZ's do not require any marking, cutting or grinding. Just drill out the holes, rivet/bolt and you're done. EZ. What is convenience worth?
15 minutes to install a set.
Not only that, I include footwell pieces that help to keep the wells clean from any build-up. The others don't do that.
These are machined to fit meticulously out of virgin HDPE. Not just laser cut with straight edges to slap on top of your boards after you hacked them up.
And they come with advanced rivets and stainless traction hardware.
The best part is that they are less than $150 per set. Super value.
Once you've ridden with plastic boards you will never look back. Especially ones that fit like a stock part. EZ.
PM me for details. Thanks, MadFab
[/IMG]
[/IMG]
[/IMG]
[/IMG]
[/IMG]
