Updates for those of you who don't follow us regularly. What is working on those 1100 Turbo's? Exhaust of course if your #1 gain. Put one of our Powder Lite(only 6lbs) or Full Velocity Stainless mufflers on in conjunction with our Turbo Outlet Manifold brings you up to 197-198hp! With charge tubes on top of that we hit 204hp! Very big gains for bolt-on's. Combine those mods with TD programming or our CMD and you have a very lethal weapon! Our stage 2 clutch kits switch you to the torsion spring which does not gain much for track speed, but does hold a lot better and shows a lot less clutch heat equaling better belt life. Not to mention they holeshot way harder.
Chains - Stock arctic cat chains are weak and stretch under bigger power and eventually fail. We have the fix with a heavy duty chain with much more tensile strength than the factory one.
Battery - The ballistic batteries we carry only weigh 2lbs and will turn your sled over while laughing.
Hope some of these products help you guys move up the hill faster! Here is a link to our 1100 turbo section where you can read more on these products. Thanks for looking!
http://bikemanperformance.com/snowmobile/arctic-cat/procross-1100-turbo.html
We also have dyno sheets posted:
http://bikemanperformance.com/downloads/dyno-sheets/arctic-cat-bolt-on-s.html
