I'm selling my personal 800 big bore kit. Its one of the new kits that uses the Arctic Cat OEM cast pistons and the kit rocks. Dynoed at 169 HP with the Stealth pipe, would be in the 170's with the Fat Azz. These cylinders have about 250ish miles on them and are in perfect shape, same with the pistons. I have some high elevation domes for it, but no head cover so you'll either need to send your stock head to BMP to get it cut or pick up a billet head cover if you want to run the high elevation domes. The cylinders also come with a set of Supreme Tool gas powered exhaust valves, they rock.
For a reference on performance, when running a 700 top end the sled would pull 68g's at elevation. Adding the big bore kit and stealth pipe I was running 74.8g's at the same elevation.
$2200 for the cylinders, pistons (no circlips or wrist pins), valves (and chip), and domes.
Feel free to shoot me any questions.
Chris.
Chris.
