I have ben useing the turbo performance girdles. it is just a flat plate that goes around the base of the carb boot where the bolts go through the boot into the block.
Carb boots still delaminate. I went through one at the end of last year. One this year. I put a bunch of the e6000 glue on the carb boot and girdle and put the one carb boot back on. it worked for a few days, but I believe it tore again. I have to pull it apart. I have two brand new carb boots I just got.
I havn't seen the peak power sports reed boot girdles. I don't know if they are the same, different, or turbo performance girdles.
Last year i used the boysen turbo reeds in the stock cages with no problems all year. this year I wanted to try the rage cages with turbo reeds. hopeing for better throttle responce and was hoping since the rage cages go up inside the carb boot it would reinforce it and hopefully carb boot last longer. I had one rage cage reed chip after awhile. replaced it. took it apart recently and another rage cage reed was chiped and torn. I just got a new set of reeds from boysen free under warranty. Going to put the new set of reeds in and new reed boots and see how it works.
