Well, that leads to a different question then... is it just the boost level that would matter or would somehow the "output" level be a factor?
For example, 9psi at my elevation is still PG levels, but at 0 feet it's full race, so how do you compare, does it matter in this discussion?
I'll push 15psi up here, but that's like 9 for some of you guys I'd guess.
Either way the boost in the tube is the same either way (115psi boost = is psi wherever you're at) so seems like guys like me who run 10-12, but are barely beyond pump gas would be in need of one more than someone running full race gas at 0 feet.
btw, doesn't the BOV only work when it hits a certain point, so then it wouldn't pull all of the boost out of the tube every time you let off the throttle, it just relieves at a certain level of pressure.
