Hey guys, went to load my sled last night and found it was locked up tight. Chain was holding on by 2 links, and the loose junk was bound up in the reverse idlers. Somehow the case survived with only minor gouging. Anyway, appears that it has a 18t top gear, and the smaller gear on the lower is 40. Since im buying a new chain now, thinking about a gear change too. 162x2.5 CE, 12psi boost for now, ride with the 2 stroke boys in the tree's and climb as well.
Pretty hard on belts, last one i had lots of black deep in the secondary, which is where my thoughts on gearing up come from. Would i benifit from 19, or even a 20t top gear?
Also, any of the BC, or alberta boys know where would stock a gear and chain i could get comming asap? Thanks!
Coxy
Coxy
