Black and oily spark plugs, adjust oil pump?
C
colo-chinaman
New member
Hey there, just decided to change spark plugs.
Sled runs just fine, as far as I can tell anyway.
Plugs were pretty gummy looking with black sludge and all black where it should be whiteish
I have a reciept where the dealer turned up the oil pump "2mm" when installing fix kit, should I turn it back down?
I haven't run the calcs yet to determine current ratio
Thanks
Check your oil pump alignment marks. I set mine just above factory specs as indicated by the pointer just above the horizontal line on the pic below.
how are you running your ethanol plug? i had same thing, black gummy plugs. i plugged the ethanol wires together and it leaned it up apparently about 5% and now spark plugs are perfect brown color. just a thought
