Biggest apex battery
hvfun
New member
I tryed a $200, Kinetik audio battery with 600 watts, thought it would be better to start in cold using race gas, Seems stock battery spins engine over faster to start better. What is the most powerful battery that would fit? Will the 20 fit? the kinetik i have in there is 7" x 3" x 6 1/2"
ever thought of maybe having a mini tank that will mix in regular gas for startup then it could be shutoff and you can run the racefuel from your gas tank?
thanks for the replys, i have the heater but may not be installed in the right place. it is under thermostat. don't really want to pull intercooler again to change out new battery.
as posted elsewhere in yammie thread about the heaters. it should be mounted down low and i would think on the side where the coolant will be flowing into the engine, thus warm coolant gets into engine quickly for fast startup. I think that mounting under the thermostat would just fool it into make the computer think that the engine is warmer than it really is. most likely making the warm up light coming off a bit early.
