bigbore piston question (cutler and d&d)
little explanation here
i have 900 stock cylinders bored out to fit the cutler pistons (91.35mm)
had some trouble so the pistons are toasted
now im looking for some pistone i could use
i talked to cutler and they told me that those pistons got designed to fit there billet cylinders and might not work on bored stock 900s since the pistonring ends running over the oilinjection ports
the research ive done so far is that this piston is pretty much the biggest what u can put in a stock bored 900
but i came across a D&D piston yesterday out of the 1010 kit which measures 91.87mm so slightly bigger than mine
question now
is anyone running the 1010 d&d kit or knows if those d&d pistons would work in a stock cylinder or do they also only work with there cylinders
all help in this case would be highly apreciated thx
Try Todd Porter at Rocky Mountain Performance in Rigby Idaho. 208 745 9040 He makes 1010 kits with 900 cylinders and might be able to get you pistons.
