B
boxster7614
This is a Big wheel kit made by Tri City Polaris. It allows you to run 7 1/8" wheels. you can run 2 inner wheels or all four. You can see there is a grove in the axel so it is offset and sits above the stock location. Tri City thought that this is the optimal set up because it give you the same size rear wheel as the front drivers and its a 1:1 ratio. Inner wheels are black outter wheels are yellow. Came off polaris Edge. $120 Shipped.
