A little info for the folks interested.(Mountain sleds only, race sleds different of course)
Series 3 860 TRA / drive
After many years experimenting with countless clutching combinations / primary and driven.
1) I only run at low elevation here in Alaska, sea level to 6,500'. Bear that in mind-(this is Alaska!!)
2) There is no way you can load to potential an 860 up here on the bottom - mid range with any, I repeat, any factory ramps, arms, /oversize rollers etc.
They need to be loaded really hard to work. (a good one that is !!)
So, here's what I've ended up with--
Start with 417 ramps. They will need to be ground from engagement to about 1/2 shift point. Compare them with a 415 ramp. When you're done, you will be lowerthan the 415's all the way to 1/2 point with-out the hump.
Stock rollers= no bushing issues.
I should clarify this is with nothing shorter than a 151" up to whatever.
If you're running stock arms, this equates to more shift on the bottom, able to swing more weight on top for the bigger track.(belt squeeze)
If you're running Thunder arms, it works really well as you don't have to load the bottom of the arms (first hole) to the point the arms are rattling bouncing off the ramps @ idle.
If you have the correct helix / spring in your chosen driven,( one that will hang on to the belt with YOUR load), you'll be happy, I know I am-------
