Best way to drain coolant?
What's the best way to drain the coolant on a 2001 Skidoo 800? I've looked, and there doesn't seem to be a way to do it that doesn't end with antifreeze pooling in the belly pan.
Thanks,
Dakotah
Thats the only way to drain unless you buy a air lift pump..I bought some large hose pinch off plyers and installed on the water pump hose and to the one going into the head...after the repair's are done...then as i removed them i added coolant to the tank and i had no air trapped in the sytem..i have done this twice this year as i had a crank go then a plugged oil line and took out the mag cyl...
Okay Take your pipe and can out then take the hosebig hose and I use a funnel with a flex in it put the hose in the funnel and out the muffler hole into a bucket> works every time
shop vac
shop vav for sure is the only way to do it. get a small shop vac and only use it for this. I have done that in my shop for years.
if you are not trying to save the coolant, duct tape a piece of fuel hose to the end of your shopvac hose, suck the coolant out and your good to go no mess whatsoever
