Whats the best turbo to put on a 2010 m8 i was really leaning towards the aerow charger but i aint to sure thanks for any help.
Your question is which turbo to use, not necessarily which company, right? In that case, my vote is for either a Garrett 2860 or 2871 on the 2010 M-8. With the 2871 being my first choice, especially in a higher boost setup. Garrett has been making turbos for many many years, they are easier/cheaper to work on, they are less complecated, and they cost less. Spool-up on the Garrett's is still really quite good. The 2860 may have the edge over the 2871 on the M-8 in low boost; however, I bet if you hopped from one to the other, you couldn't tell the difference in lower boost set-ups.
When I was putting Garrett turbos on cars years back, I found them to be one of the most reliable on the market, at the time, and a lot of science went into their build. They just work.
As for which company is making the best kit....do your research. There are 4 companies on the market right now that I think you cannot go wrong with. If you have too, just use a 4 sided coin.
