Is it damaged/tweaked/buckled NOW ... OR... is this preventative measures??
preventative![]()
If your sled is already damaged... I Highly recommend the Vanamburg tunnel brace set... Cut from CrMo steel... very nice fit... but requires some disassembly of the sled. VE makes nice stuff.
.I'm running the FastTrax Tunnel PROtector kit on my current sled and will be installing it on my next one as well.
Install it on a new sled.. before you buckle your tunnel
IMO... It should be one of the first upgrades on your PRO RMK for anyone that crashes or hits stumps/rocks with their pro chassis RMK's...high quality laser cut stainless steel parts.. even has the long drill bit you'll need..
You don't have to disassemble the sled to install it.
Before anyone busts my chops ... YES, I paid for it.
When I first had it in my hands, I was pretty sceptical about it. I had a chassis torn down to nothing to do some other work and I installed the kit so I was able to actually feel the before and after... Before that whole area was flimsy... the FTX kit locked everything together and sandwiched the tunnel in that weak area... worth the money IMO.
Good call IMHO
It's Way cheaper then doing a tunnel mid season.
Knowing what I know now.
It will be the first thing that I do to my new pro.
Mine bent from a rear heavy landing on a very small jump.
I have taken way worse hits with all my previous sleds and not one bent the tunnel.
Whats ur definition of a small jump? My definition is say like 5-10 feet total vertical. 10-20 medium. 20-30 big. 30+ friggen insane (for me)!!! When I hear of bent tunnels I think of real bonafide Slednecks guys hucking 100 foot cliffs. Ill do a 30 foot cornice no prob but haven't considered myself a likely candidate for wrinkling the footwell area... I can see the tail bending easily if u land right on it. But u guys doing this stuff are you pro riders or average joes?
I wasn't from a drop. It happened on a 40'-50' step up at 50mph or so, to a flat landing spot. I landed at roughly a 45 degree angle. i flew maybe 10' above the landing. Too much throttle not enough braking ! Didn't hit that hard either, not hard enough for me to look at it on the hill. I found the damage when I got home.
