Getting ready to replace the trailer tires (Nankang 185R 14C) on my 28' enclosed trailer and want to hear from you guys what tire you recommend for winter hauling.... Thanks!!
i've had good luck with goodyear marathons..
It's really too bad there is no super awesome trailer tire out there. I've tried many brands and have had many failures. I'd say that I've personally had the best luck (least amount of failures) on Tow Master tires... even though they are Chinese like a lot of trailer tires out there but much better quality IMO.
Forgive if I'm dense, but if trailer tires are all junk why not go with a car or light truck tire? Honest question too...not being a smartass
More so than a light truck tire? Can't imagine so. How many blow-outs do you hear of on loaded 1-tons? Can't imagine the average sled trailer weighs any more than that?I remember reading that the sidewalls on trailer tires are beefed up more.
Jay, one thing that makes a diff...the diameter of the tire, bigger the diameter..less times flexing per mile compared to a smaller tire..you take a little tire on a 2 place..that pore thing probably does 4 revs for every one of the truck...meaning the same spot on the sidewall is compressed 4 times vrs 1 time...which makes more heat....same with a wider tire..more area on the ground..more heat made....More so than a light truck tire? Can't imagine so. How many blow-outs do you hear of on loaded 1-tons? Can't imagine the average sled trailer weighs any more than that?
You have a pointI've noticed alot of trailer tires are not balanced. Wondering if that might be a problem waiting to happen?
So what do you reccomend adding above recommended preasure on the tire to prevent possible blowout?blowouts are normally related to tire pressures and load..any tire will blow out if it doesnt have enough pressure in it to eliminate most of the sidewall flex(My grandfather owned a mobile home moving bussiness when I was young..most people couldnt haul a 14X70 trailer 10 miles without blowing tires at factory pressures(80psi), he kept adding pressure till they held up(120psi )..never blew another tire..why? stopped the side wals from flexing..now I dont recommend you over inflate your tires..but rated load/vrs load/ vrs pressure is important....
