After a couple years of wear and tear on my sled deck, the cheap plywood is starting to split and warp at the edges. It is coated with some sort of paint that is holding up pretty good, but edges of the ply soak up the moisture way too easily and are starting to split apart.
What has everybody found to be the best material to put on open trailer decks and sled decks?
I've thought about the plastic Trex material used for house decks, marine grade plywood, and another option using regular AC plywood. What I would do with regular AC ply would be to make all my cuts and holes in the plywood first, joint the edges with like 1" strips solid lumber (like fir or redwood) and then take it to the local pole plant and get each piece treated. This way every edge and surface that is exposed to the elements is treated and very little of the raw plywood edges are exposed for moisture to wick in and warp. I know it sounds like a lot of work just to deck my sled deck, but I think it would make it last alot longer. Plus plain treated plywood won't be so dang slick as the painted plywood I have now.
Might also help if I don't do the drive through car washes...I can probably keep more moisture off the deck by doing a manual wash.
Anybody have any thoughts?
