Best Torsonal conversion kit?
ultrasks700
I have a 10' M8 that I purchased a stage 1 speedwerx clutch kit for, which was only different weights and a primary spring. Set up pulls good but I've been ready about secondary set ups and I'm thinking about getting a torsional conversion. Just seeing what other guys have purchased and what you choose for Helix, ect. I'm at sealevel-5,000ft.
Pm'd you....
I've run the CPC torsional conversion for about 15 years on many of my sleds. They have great personal input for your application, elevations, and Mods. I like the Speedwerx stuff also in the primary. I'm running the Hammer head primary weights with H5 Pri spring. M1000 uses a 42/38 with speedwerx single pipe. Like the set up. Secondary is a Red/white CPC sec spring. M8 would be different though. Call them.
I've ran a few Rk tek secondary's on my m sleds. They work good and Kelsey is good to his customers.
Bru
Bru
x2 on the RKT kit I really liked the one I had on my M7 the backshift was quick
When ordering a Ovs turbo kit in the past. Garr said that RKTek and Ovs were working together to make a torsional conversion. Kelsey ended up splitting with the idea and making it for himself. Ive had both, both are very similar, But the install on the Ovs one is simpler. Both are pretty hush hush on the angles though. Not sure if they are close to the same angles or not.
If Kelsey isn't making them anymore, Dale's newer kit is a solid one, I preferred the RKT, but just make a point of avoiding dale's OLDER conversion (pre-09 I believe)... never had much luck with those, don't think they'd work with reverse anyhow.
