What is everyone finding the new engine likes to be at for rpm?
On the dyno 8100 and 8200 make the same hp. But 8100 makes 2lbs. More torque. 8300 you loses 2hp. 8400 loses 5hp. Not sure what fells best but this should help.
2nd sled (mine) running belly buster weights, yellow Team spring, TKI belt drive 2.26 gearing, & 8 tooth drive out of a last years Pro.Stock Secondary other than the D washer in both clutches / Primary balanced.
How do you like the team yellow spring, engagement isn't to harsh making it trench taking off? What size of belly busters,64s?
Wow, 7mph with gearing. Makes me wonder if I should move my tki to my 16.
FWIW -
Testing 2 Axys this past weekend 9,390' elevation both 163 2.6 with the QD.\ both 210 miles- both ES. Have ran with eachother all along since new- so tried a few things.......
One stock everything/ didn't change a thing ....
Same hill- several good pulls-- bottomless snow, trial runs after each other and the stocker was about 1-1/2 sled behind constantly even switching riders.
Stock RPM 8150 /8200 38 MPH track speed, 100% throttle
2nd sled 8350/ 8380 RPM 45 MPH track speed, 100% throttle
Both have the PIDD and we were in the clutch mode recording runs./ and final gearing is the same on both sleds.
So dunno what SLP and other say the peak RPM is supposed to be at stock motor, but is was sure evident that the minumal work on the second sled, sure was very noticable.
Going to try 2.33 gearing this weekend ( mine) and see if there is a gain/loss...vs the readings and against the stock Axys.
Like to know what Peak RPM is supposed to be at elevation- dunno know if I am falling off or right at it.. but sure runs way better.. 15.8 hours on the motors
S/C
The reason(old school I guess)reducing the angle of the track coming off the drivers,rolling resistance, and spearing the track has been lessened also
All I can say for right now is, the motor likes to spin and with not a for sure a 100% correct rpm/ torque at elevation spec ( still digging for that one)- doing what is working-and getting very respectful results... I don't want to have it diggin to china- but it could be better suited for tree bangin'( on/of throttle) with the next step of gearing-
For boondocking group- but I think we have that one pretty much addressed with this driver swap/ clutching / and gearing.
Sled is lovin 8300+comparing to 8100+ all w/Stock pipe- but aftermarket can
With the TKI- it's only a matter of less than 5 min to change the ratio back and forth....
7 tooth drivers ..... nope not ever again- flatter track angle to the rail tips, easier rolling resistance ( old school again), and just as much clearance as a 3" w/ 7 tooth at the front, that just got into my shop today.
The QD sticking down is more of a concern than the very very minimal of the 8's drop but that QD pimple,has a custom hard hat on it now from Fire-N-Ice
I'll try to get some pic's
S/C
