Mountaintech
I am just curious what types of issues did you encounter doing your testing that helped you decide > 3" was too much on the nytro. Besides the obvious things like upper shock mount locations, shock geometry, and clearance issues with tie rods. My intension is not to bash or disproving anything here. I am just curious what you came across in your testing.
Therein lies the Nytro's issues - too much weight too high up and too far forward - everything is centralized but unfortunately its mostly ahead of the rider.
Still surprised that Yamaha couldn't have addressed this on their own. To fix the issue(s) you have to throw gobs of $ at it.
I ride at close to sea level so the NA Nytro has lots of power but handling sucks!
To get it to where it should / could be I figure that it needs:
1. A-arm forward relocate kit (Yamaha could have easily redesigned / repositioned the front clip to achieve same results)
2. Steering post relocate kit
3. Lightweight skid (after market, Cat float, or Mtn SE version)
4. Exhaust work so tank can be lowered and moved under the rider seat (increase capacity)
5. Boards - again Yam could have easily doe a variation on polaris stock boards
6. Tunnel cooler + rad delete
7. Lightweight battery
Basically a 40 to 50 lb weight loss (more would be better - but 50 lbs is reasonable) and better balance would make it a truly fine, capable, dependable sled but what does Yamaha do ....
I've said it before and I'll say it again, despite the lag and the blah blah blah of the rear mount the forward weight issue is why I will never do three things. Run a front mount turbo, run a supercharger or EVER run a trail tank (total POS). For me strictly for the improved weight balance its rear mount turbo spare gas on the back where it belongs. JMO.
M5
