bent ski
Put mine in the hot tub overnight and wallah. 95% fix. Did the rest as stated above with a heat gun and clamps. Good luck. EW
Hot tub is a great idea. Not sure if the chlorine would break down the plastic though. I had a bent saddle, put a bar clamp on it and placed it on the heat register overnight and it looks like new.
run a bathtub with just enough hot hot water to cover it. Put ski in . Go boil some water and add some every 10 minutes.
Within an hour, your ski should be back to its original shape.
The ski is probably made with UHMWPE (ultra high molecular weight poly-ethylene) which does have a memory.
