Belts????
I have a older tra2 from 01 that im running on my rev. From what i have gathered, its 12 deg. Im running a 127, what i had on my zx. The 127 is a little longer and my belt deflection isnt where i would like it. I was just wondering if i was able to put a 166 or 288 on??? If it help also, i have a team roller. Thanks in advance. Steve
I wouldn't hesitate to run either belt if they are the correct length for your C-C. The -288 is quite a bit more durable.
Is your sheave angle on the secondary the same as your primary ? The 166 and 228 were for a tra 3 that had a differnt sheave angle I dont know how thats going to Match up ?
im pretty sure the seave angle is the same on the secondary. im not sure where i could find that out as i never bought the clutch new. i have a belt at home so i may just try it and see what happens. will keep you guys posted. thanks for the input. steve
I wouldn't worry about the sheave angle, it's variable on the TRA....steeper towards the bottom, shallower at the top.
