Just that simple...what is everyone using for belts out there?? I have a 900 fusion 50th , anyone run the ultimax xs 809 belts?
3211115.
I have been running the 3211080 on my 975 with no problems.
3211080 $80
3211111 $165
3211115 $179
What do I gain for $100 with a 111 or the 115?
When the 900s came out, they were destroying the 080 belts on a significant scale. The 1111 and later the 1115 were created to withstand the massive torque and heat generated from these higher output sleds. As has been said before, blowing a belt on a factory 900 crank is VERY bad for it, if it even withstands the initial attack, its life has been severely limited by the extreme shock force given under WOT.
If you can get 1,000 miles on an 080 belt it sounds like everything is spot on and working perfectly, but many sleds will simply eat them for one reason or another and the 1115 was designed to be that much tougher.
