So last year I had my belt set up perfect with the grooves just above the sheaves on the secondary, and engaging at 4200-4400 rpm. This year I put a new belt on and had chain case apart while doing a track extension, new drivers, ect. Sled will roll ahead with any throttle and then die if i hold the brake. Track will also turn if i lift up the back. I have tried playing around with the jam nut adjuster but cannot get it to release and allow me to lessen the belt tension. Any ideas?
I am thinking maybe the sheaves are stuck together but this is only a 12 600 with 860 miles so clutch should not need rebuilding.
