I took my sled out for a quick run yesturday and when I stopped, and the motor was at idle, the belt squealed bad. It is a NEW belt, so is it just breaking in or is it too big? thanks, Mike
Check belt deflection. You can adjust that by adjusting the secondary clutch. You need to spread the secodary sheave out. What kind of sled do you drive?
nope, the belt should always ride with the seam on the top edge of the sheave. If you spread the sheave the belt will be sitting intoo far. You actually adjust the pulley distance / alignment. On the Doo's you can back off the engine stop slightly to acheive the appropriate belt deflection, don't give directions if you don't know..
