H
hockey1004
so i used the threaded "L" wrench and put it in the threaded hole and twisted it so i could get the original belt off and to put the new belt on. i then unscrewed the "L" wrench back out and im not sure what that piece of metal is called where you use the "L" wrench, (maybe the primary) but my question is, is that big piece of metal is now loose or i should say that center bolt right next to where you put the "L" wrench is look and the piece of metal moves back and forth. so how do you tighten that back up or will it do it by itself? also is there anything else that needs to be done after putting the upgraded belt on (any torqueing?)
thanks all for your help
