Belt question?
so to start off i ride a 06 m7 and i it has the m8 clutch if that makes a difference but the belt squeals when im at an idle when i rev it up it goes away does it need no be tighter? and if so im not really sure how to tighten it, your information would be great:) Thanks
No
No you do not want to tighten in any more. The question is do you want to loosen it. If it is just a very light squeal you should be ok, but if it is loud you will need to adjust it. I have always had good luck running the belt deflection where the track will just barely turn when it is warm on a track stand.
You can also measure it but I would have to look it up to say the right number.
